Peter
You should never attach a DdRT system to a ascender. If you shockload the system the ascender can sever the SRT line. Shockloading is as easy as slipping off a branchwalk.
Much better to tie an alpine butterfly in the SRT line and anchor off that.
Again, bear in mind with a conventional SRT line setup, anchored at the base of the tree, there are serious risks to consider when using an inline anchor. Doubled load on anchor point, rope between anchor point and tie-off getting damaged, and any limbs you cut getting caught in the SRT line. Any of those is reason enough to isolate the anchor point IMO.
 just using one as a metaphor for the other.
