CurSedVoyce
California Hillbilly
I think one of the guys on the forum .... welded plates on the sides rear to take those hanging tractor weights. Brendonv I believe.
Got any pics of the push system?
I would add some lead or steel, not too much though, maybe just 50lbs to the back riding platform. You don't want it too easy to tip backward when unloaded (such as when driving uphill). I've always wanted extra weight in back on a sk800, but I'm only 145lbs. I have doubled up with a 180lb guy to load some giant chunks of wood (800-1100lbs), but doing that enough seems to have slightly bent or loosened the grapple attachment point to where it wouldn't lock in place anymore. I think it had to be rewelded once. Supposedly the sk1000 is like 500lbs heavier, but the same size machine.
You also just have to learn how the thing handles to use the imbalance to your advantage.
I think one of the guys on the forum .... welded plates on the sides rear to take those having tractor weights. Been in. I believe
