How's the splice today?
  • Thread starter Thread starter Wagnaw
  • Views Views 288K
@Tommy_B
Do you use a wire/long steel rod fid for the drenaline?
I have been watching the splicing vids and all it seems to need is patience and a 50cm or longer wire fid
@Tommy_B
I use a piano wire fid mate. New rope is super easy but this one was a bit tougher as the cores weren't sitting completely parallel. Push the fid up the outside with a bit of slack in the cover and it's fine
My understanding from personal experience is used rope is a mofo to splice. Perhaps not so bad if it lightly used
It ain’t fun either. Used rope just takes more time and is frustrating. One thing I’ve found is that having more line before your cleat is better. It seems that having more cover to work with helps final bury.
Ha, used rope was the first and last time I did splicing. It came out well but yeah nah:/:
I spliced a used climb line once, a well used one, after a chainsaw(s nick.. The main problem for me was to extract the core. It was like glued inside. The inner strands were molded by the crushing action of the outer strands. The fibers were probably worn out too at each contact point, but they didn't show any major damage. The core seemed to have the surface of a threaded rod.
I tried used rope once also. I appreciate your descriptions which evoke my experience. One image I used for extracting the core was “like Velcro…”
I will never do that again unless it was some great emergency! It’s hard for me to imagine an urgent situation that I could not deal with using knots instead. Maybe stranded somewhere I can’t buy new rope. Lots of time but I need maximum strength out of a used rope.
Do you have an alternative?
I wrapped them then stitched them together the legs of elastic….
Just trying to get a cleaner elastic than a knot…. Need to get some tight wire crimps er something.
These elastics are just bungee cords w the hooks slipped off…. The original binds look like these hog rings you mentioned…
A mini carabiner fits perfectly.
If they don't pull apart, leave them as you made them. If they do, try another method...the hog rings/shrink wrap would work fine, I'm sure. It's not rocket surgery, after all.
I have always just knotted mine in that app. Maybe I'm a slacker, but knots suit me just fine. A sliding fisherman's is handsome and compact, and stays tight to the mini-biner.
20260318_224836.jpg Used Drenaline. Had to back the fid out on the cover bury as it was definitely not playing ball. Got there in the end.
Who can spot the "mistake" that is causing me immeasurable professional shame and embarrassment?
  • Like
Reactions: FJR
