SeanKroll
An SRT device is the safest way to the ground. Your rope doesn't have to move. A HitchHiker will allow you to move down a rope even if there is a bunch of weight on it, like the limb or log you just cut.
Carrying your rope (only need to be long enough to get to the ground) is a good bet, but heavier.
Saddles are meant to be sat in. Spurs and a "belt" are the old school way, without the ability to sit.
Have you seen Coffee Break with Hap Johnson (IIRC)? That guy has been up a tree or two, belt only.
Do you keep it simple in the metal shop and just use a hacksaw? Climbing with spurs and lanyard is great when you only need everything to go right, and are not interested in any support from the leg-loops, only the belt, without a speedy exit to the ground, nor any need to pull anything up.
My "boring, lazy tree work" includes sitting around as much as possible and doing everything the easiest way that I can. I stand in spurs when working down a spar, IF I don't have another tree adjacent to me to anchor my climbing line.
