Wood stove heat
  • Views Views 146K
Regular black cherry or apple is the best I've noticed. Never burned chestnut oak. They're around. but still living. Hickory's nice too, and I've had black locust that smelled a bit like smoked ham. That was pretty good.
Love all the different smoke and smells indoors and out. Except for Poplar and Staghorn Sumac , of course Cherry and Apple love ... best smelling heat is Juneberry. Small trees so it's irregular and random when on the pile
Great comments but, er, I rarely if ever smell any smoke in the house by stove (while feeding logs etc) nor outside so are you gents talking about campfires?
My stove needs work. The glass is messed up up front, and I feed it on the side. That causes smoke to puff out when I open the side door. I need to fix it, but keep kicking it down the road. Easiest fix is to block off the windows entirely, but I like seeing what the fire's doing without opening doors. There's a few ways to fix it readily in my skillset. I just need to pick one, and make the time to do it.
Those are great old beasties. Far too many have been kicked to the curb in my part of the world due to not meeting EPA regs when a house changes hands, per local law.
You did good!
Yoooo. Question here. Now that I'm retreaded, I'm burning a lot of wood everyday. And I'm happy to report btw that my wood supply is working out quite well I think bc I made sure to cut all pieces reasonably short to help with the 100% hand splitting and I split all pieces a lot as in no big chunks. Those 2 factors I believe facilitated faster drying in my large stacked pile covered only on top with one sheet of clear plastic.
The problem I'm having is with coals. When I load up the empty firebox in the morning I get great heat out of the resulting roaring fire. Eventually of course, the logs burn down and the heat output lowers some and I then add more logs and the output rises again. Rinse and repeat. But after about 5 hours of this, eventually the level of red hot coals builds up quite high in the fire box thus physically limiting the amount of room available to add in more logs so therefore I get a reduction in heat output despite the box containing a large amount of coals.
No doubt you wood stove savants have some answers... :popcorn:
Maybe I should just remove some of the coals when they build up too much though I smell a rat regarding handling large quantities of red hot coals
I find there is usually a lot of ash under the coals. I sweep the coals to one side and shovel the ashes out, the sweep the coals to the other side and repeat. If you had a metal container to hold the coals and had a safe place to set it down I don't see any rats.
The sweep method works ok, just not great.
I handle it like Rich does, though burning somewhat less dense fuels like we have here in my part of Oregon (Doug fir, BL maple, red alder) that issue doesn't really come up often. A deep bed of hot coals generates plenty of heat output from my stove, generally.
