A little pull to one side with where the boom is, and an accommodating cut, gets the tree away from anything that could be damaged, in this case, something quite valuable behind.  Yes, it was a bit over emphasized, and I get your concern with it, Butch.  I respect your take, know you have done mucho crane aided removals.  I knew which way the thing was going to swing, the reason why the cut gets opened more in that direction, and away from me, set up between the operator and myself before hand, or I can generally just look at the boom and see if there is some directional thing going on that he has in mind and can orient the cut, or ask him to move the boom a bit myself.  If there is some confusion, will always clear the plan to eliminate concern.  We've done many hundreds of trees together, and pretty clear communication with a hand signal or whatever, as to what is planned.  Sop here.  As you point out, a gentler lift is generally preferred.  Will use a rope sometimes too, to hold a pick until the lift is deemed safe.  No way that I would be cutting on the other side in a situation like that.  I've had trees swing by me close with crane picks, too quick and little room to respond, definitely not a good thing.  He didn't need so much lift in that case, but not a worry.  He did bounce it, I dunno, cold or tired at the end of the day...?  All in all, things generally go a bit smoother with a straight up lift.  No biggee imo.
