MasterBlaster
Administrator Emeritus
I see that way.
Just reading that gives me a headache so I guess that means I ain't got it.A good vestibular system, and spatial-relational intelligence goes a long way.
...also as Sean says, practice, practice, practice. It's a learnable skillset.
.Wow, Gary!! I am deeply honored, sir. Funny that you and Chris should feel the same way I do... I remember having the identical conversation with Burnham at flip-fest. I absolutely SUCK at holding the bar level, and I've tried EVERYTHING and then some. I glued a bi-directional level to my fly-wheel cover years ago. I've carried a marble around with me to balance on the bar. I've "cleaned" out my cuts with throttle pulses till I could see daylight right through the cut just for the sake of lining up my back or diagonal cut with the initial one. The marble is the only thing that helped. I'll just stand there in the yard, and balance a marble on the guide bar, and then try to "record," how the bar-tip looks in my mind, and how the handle-bar feels in my hands. I'd do this with the motorhead both ways. (Regular, and Full Wrap). Now that helped me out a bit. I still suck on steep ground. When I'm on bad ground, I try to imagine what "level" looks like, and then overcompensate with both "roll" and "tilt". Odd thing is... it usually comes out pretty close. Clear as mud, eh?
Good to see you looking up at the top of those dead trees, Gary. Really well cut too. Nice fall.
A full wrap is great, but not necessary. Kinda like air conditioning. A full wrap would go a long way on your 461, IMO, especially if you need to use it in the tree. Maybe buy used, and sell your 1/2 wrap to support the full wrap purchase. If you need a handlebar as a spare part, you usually need much more than a handlebar for spare parts.
Once you go Full-wrap, you never go back. Until then, you just don't know what you're missing. Kinda like big dogs, and wedges.
Damn me, but I must be stupid to not understand this problem...I can't say how many times 30 seconds or much less with a shovel made my full wrap handles a moot issue getting right down alap for stump cuts.
Or is it that the rest of y'all lazy bastids are missing the easy way to have the benefits of full wrap handles without any downside??? I'd trade the minimal effort to make a low enough area to sweep a good alap stump cut over never having all the value of having a full wrap handle day in and out, any effing day.
Blah, blah, blah..................the whole world isn't the PNW, Sean.
Come work with me a season in the woods here, making stumps the required way and then sing your praises for full wrap.
Same goes with the big dogs.
I bought a pair, tried them and found them to be TOTALLY worthless when cutting smooth barked hardwoods close to the ground.
Ended up giving them to a fellow treehouser.
