squisher
THE CALM ONE!!!!
Cool pics Rich. Looks like a hell of a hiab. And that tractor setup looks sweet too.
I'll use two bull ropes before I'll use a spiderleg.
I guess we don't even think to do spider legs, since our GRCS lets us crank the limb to have pre-tension so it doesn't budge when cut, or crank further to lift it up to clear higher limbs.The spider leg isn't to be avoided, it's very useful when you have no room under the limb (aka close target) nor you can't lift it (other limbs over it). Tip drop or butt drop can be both forbidden. The limb has to stay as is (with its initial angle) during the lowering. You do that by tying 2 or 3 legs of rope, before and after the center of gravity. By fine tuning this setup, and properly guessing where is the COG, the limb barely move when you make the cut. More easy to say than to do, but interesting.
Edit.....(and this is why I sometimes multipost in sequence...frikkin' Squisher already butted in while I was crafting this eloquent reply/bolstering of the boss.)
ESTIMATING the COG is the thing...my estimates suck sometimes when I have tried spider legs.
Here is how Alex and I handled a large limb in a tight space yesterday...two lines as the boss decrees (OK, suggests in his omnipotent wisdom....)
2nd line is there but doesn't show attachment which was near base cut at spar. Groundman (only have one when I am lucky) has to work like two monkeys to lower sometimes...when I can I take over the close line and handle it.
We gotta finish this one tomorrow. I hope it is smooth going. I get to break out the 42" bar for the second time, I just hope there's no metal or rocks in the tree. I modified my oiler too to keep up with the big bar.
View attachment 87947View attachment 87949
Anyone know if a 134DL chain will fit a 42" bar? A new 135DL already has the tensioner half out, and it isn't long before the end is reached.
by the time you’ve rigged it all up, got the balance wrong and generally arsed about you could have rigged it out in smaller pieces.
Why the undercut in the last lift???
So that's what the pic of the odd hole in the roof was about...
