Scott- Great looking tree you freed up there! :thumbup:
Gary- Solo:\: You must have muscles in your shite after that one.
Worst part was unraveling the mayhem of the bombing and dragging the brush...gravity did the high stuff.
A friend with a big bobcat and grapple is doing the big wood.
how does the effective force on the tree change as opposed to a direct pull, if obviously you had the room to pull straight. Cant quite wrap my head around that at this time of night.
Good work going on there Gary, I like the rigging set up with pulley, its nice when you cant pull straight, its very effective
No, same as a direct pull, no advantage. The block would need to be on the pull Tree to gain advantage
Quite right.
I believed the rope he was pulling was connected to the anchor tree rather than the tree to be felled.
On closer inspection it isn't.
I'm not saying a 2 to 1 just not sure it's equal pull. If the pulley was on a fixed point yes but it's not, that pulley is able to move within the constraints of the rope. I might be totally off point on this but all I'm not sold yet.
Let's ask Graham , he would know
It's a redirect with no MA.
the sling will feel increase force (greater than tree or truck) IF the angle is less than 120* between the legs of the pull rope.
The pulley in that pic can move slightly but for all intensive purposes it's a redirect. Any gain is minimal.
Very correct Sean. When I was setting rigging for the crane in construction we would make sure no slings were over a 60 degree loaded angle. Any more than that and you lose strength. Makes sense since a triangle equals 180 and an equilateral is three 60 degree angles.
Ok now that I've dealt with the upset child who never wants to sleep, it doesn't quite make sense. Anything less than a 90 degree rope angle would add more force. Depending on what you want to call the rope angle. I'm calling the rope angle the apex the rope angle. Should be greater than 90
Gary would have to be driving at the tree thats being felled to be 2 to 1
Not that either, that would double the load on the redirect Tree, not the fall Tree. If the block were tied on the fall Tree and the truck rope were tied through the block to the leave Tree then there would be a mechanical advantage, or actually in that case maybe a disadvantage because the angle is so wide.... now my brains mushed
Hauled Friday's leftover wood this am, got Justin some boom time. 20170228_105907.jpg 20170228_105929.jpg 20170228_110123.jpg 20170228_111137.jpg 20170228_113702.jpg
Then picked a tree that had been topped and left standing years ago. It fell into an old single wide recently, very bad Tree to climb.
20170228_142346.jpg 20170228_144818.jpg 20170228_145025.jpg 20170228_152953.jpg 20170228_153016.jpg Screenshot_20170228-173335.jpg
  • Back
