Saw that elsewhere.
i had a similar (if smaller) one last week, dozens and dozens of branches, half of which were above a building.
Technically easy, but painstaking and quite tiring if I’m honest.
This was a pull down, set at the TIP
Maybe I don't fully understand what you did. Here's what I did step by step...
Throwline into tree, weight's on the ground
Tie off climbline to throwline, haul it up and over.
When I get my climbline end, I tie a butterfly on the part that's on the rope pile side(not the end I just pulled up)
Put the end in the butterfly, and start hauling.
If I have enough rope(I did), that left me with a climbline, and a retrieval line.
If I did not have enough rope, I'd have tied my throwline to the retrieval side to get the whole way up.
I guess I will have to paint a word picture, sorry I’m not as good a wordsmith as @Kaveman…and I’m falling over tired. Hot tub time.
Burnt conifers. Last time I was up here (cencal mountains) it was a playground ready for felling after the caldor fire. Now, Brush taller than my 6’ head plus helmet….bushes not so bad other than seriously impeding movement but interspersed with blackberry vines. I thought I’d knock over 20 trees or something today…only got several , and a bunch of limb tied burnt saplings that were always in the way that I had to cut paths to thru the brush. I was reminded of my previous post about proper swamping…cut brush too low and you risk the chain. Too high and you have tripperstabbers.
I only took one vid and a few pics.
I put a cable on that pine to be sure , but like I expected it didn’t need it. I wish everything would hold like that 😒 it’s crazy how brittle, springy, and wedge-spitting everything else is.
(Three more vids after that if you swipe 😉)
Today I cut down 6 birches and 2 pines.
The most interesting birch that grows out of the fence. I was asked to cut it down according to the fence level and stop there :)
My assistant on earth got sick today (and so I had to work alone. However, I did it all in less than 5 hours.
I'm shocked myself! I guess I'm a cool Russian hacker :) In fact, I use the app to upload photos Postimage.org. You need to log in to this app and upload a photo. There will be several options, but you need to copy the link to the forum. Then you need to paste this link here and change it a bit.
If you need to upload multiple photos, you just need to enter a message after each photo link. Thanks for your attention! If something is not clear, ask a question.
