pigwot
M's, Juniper's, Lowen’s, and Inge’s Grandpa
Found Avibank Mfg. in California, model 5M100 (5 = 5/16" dia., M= cup handle style, 100 = 1.0" working length)
not having midline is not a huge deal, it only takes a minute thread the wrench thru but you can always get a ball lock pin, 5/16ths, 1" long and replace the top bushing with it, VIOLA' mid-lineI'm pretty much sold on the idea. I just need a midline attachable one to come out. And I'm ok to use Ddrt until that happens.
Nice review, Cary.
It beats the heck outta the unicender. IMO.
this stuff should be plenty strong enoughYou thinking of a wire tether Burnham?
Burnham,
I see where you're coming from. A hitch designed to function alone on SRT is a hazard in my opinion, as it trades slide-ability for grip-ability.
A standard Ddrt hitch would never work alone on SRT as it would lock tight, but is inherently more safe when used on SRT with the RW.Gerry,
I just spoke to a manufacturer of the cup-handled, recessed lock pins and surprisingly he said they get almost no requests for them.
Have you seen them available in the 5/16" dia. 1.0" working length size?
Maybe marine supply companies...
Early on I tried single line with a friction hitch and found out right away that it didn't work. And also much later,, with some certain descending apparatus. With single line two devices in combination are far better than one. Many combos possible. The RW/FH is but one.
I would be curious to experiment with other combos. What else is there?
That place is a whopping 20-30 minutes from my house. Let me know if I need to do a recon mission.
Thats cool, I hear you. I have committed myself to letting myself breakthrough the learning curve on the UNI. I have learned many times not to give up on something just cause I'm not good at it... yet....
You are right about the rope wrench, the system will not work without it, but... your life will be fine without it. Your life will not be fine if you are trying to use this alone or with something that is not life support. Does that make sense? It is different to be stuck in a tree an have a hard time coming down than crashing to the ground uncontrolled.
If the wrench is on or if its on or off, it doesn't make a difference to your being alive. Or it shouldnt if you are diligen in tying good, safe, and stand alone hitches.
I have had the wrench pull tested and broken in every direction and it exceeds 6,500 lbs whichever way you pull it. If I were to put that on the wrench, (MBS 5,400, etc) it might give the impression that it was meant to be used as a fall arrest tool or as a connecting device. Not the impression I want to give. It has to be loud and clear that it is not life support and not intended to be used as a stand alone tool. That is really the only thing about this tool that has to be completely and thoroughly understood in order to use it.
