Finally got around to falling/felling this Loblolly(?) Pine Tree.
Here are the pictures to finish up the thread.
Loblolly(?) Pine --- ~22" x 60'
#1
#2
#3
#4
That's kindergarten stuff! ... yeah, I know.... but because in large part to folks' here comments... tree is safely on ground.
self-assessment...
THE BAD AND/OR UGLY
* adrenaline/heart/respiration going so heavy I didn't take it all in while it was falling to enjoy the thing crashing down -- "D"
* my son was watching me (for safety) but I forgot to get him to film me (so I could review my actions afterward) -- "F"
* when the tree started to fall, I quickly stepped away... but it was a relatively small tree and I stopped about 8' away -- to the side -- sort of hypnotized watching it.... aware that it could hit the ground and the butt bounce/lurch/lunge/roll at me.... so I was ready to move.... but I should have moved quickly back 15' away to watch it fall. -- "C-"
* used not so sharp chain to cut down the tree... not too bad on plunge/back-cut, but horrible on face cuts -- "C-"
* forgot to put out a marker to estimate exactly where I wanted the tree to fall and see if my estimate of the height was correct -- "C"
THE GOOD ... or "ok"
* good aim -- tree felled/falled in almost exactly the lay I intended it to... missed the critical targets... no damage... EVEN though tree was twisted and bent and leaning away from intended lay -- "A-"
* level back cut and hinge -- back cut at hinge is pretty level with front of hinge... not too ugly -- "A-" or "B+"
* thickness of hinge -- hinge thickness was off some ... about 2.5" on the close/good side to 4.5" on the far/bad side ...
....was afraid of cutting too much off far side.... I had wanted the hinge to be thicker on one side... but I got the wrong side thicker.... if it had been 2.5/4.5 reversed I would have given myself an "A" ... but since such a heavy leaner the extra thickness didn't matter much -- "C-" to "B-" (since heavy leaner)
* decent face cut -- not a perfect "V" but no dutchman and it is even with the hinge -- "B+"
so what's the big deal with this little pine twig?
Well if you don't have anything else to do.... any comments and assessments -- humourous or otherwise would be much appreciated!
