milling thread
  • Replies Replies 2K
  • Views Views 319K
4 ft 7 inch slabs
Slabbing 24/4 for resaws and some 12/4 and 10/4 all 16 foot log is 63" tall and 52" wide on big end at biggest slabber cut only
Rob got the new blade sharpener set up for the mill blades.This will save us some money over time. He is sharpening up several bands to start cutting my joists for the deck.
Some maple my son and I milled last weekend. Kinda enjoyable, but white pine sure slices up easier and faster!
Dang, Denver...that is so cool. Down and dirty work cutting logs...and then you see a laser beam helping direct the work...cool stuff.
9' log. Sugar maple. Milled everything 2-3/4" thick, and found the slabs are somewhat heavy to lift!
Was taking us about 9-10 minutes on the widest dia. pieces which were about 30" on the butt end.
Am a complete novice at milling, so I dunno if that time could be improved with better chain filing.
Using Stihl ripping chain. Think I have the rakers a tad low for hardwood, (a bit jumpy), but cut smooth on pine.
This is the mill at work with my extension on it. There is another 12 foot extension there but it's not hooked up yet. We'll be able to do 57' then.
White oak moves a ton.
In 2013, one of the only mills around that would custom cut oak wanted $3.80 a board foot for 26 foot long white oak. This timber has 380 feet in it. Should be at least $5 a foot, would be my guess. Finding white oak that will make timbers like this isn't easy here.
