Magnus
That is OK, I can except a good explanation to were to find the info and parts that recognizing altitude!
This is exactly how it is. It sets after current conditions.As far as it checking altitude I see no reason why the saw would need to know that.......it's just looking for the correct tune no matter the elevation.
That's not right Chris, take it into your Husky dealer and have them look at it. My 562 starts on the first pull even after the saw has been sitting for a while lukewarm.Love my 562. Doesn't start on the first pull even when warm though.
Good talk here about the AutoTune technology.
Here is a pic of my 550XPs my Husky dealer gave me through his sponsorship for my chainsaw speed cutting events at our local winter festival . We just finished up the competition last Saturday, so I have been very busy in my abscence here for the last few weeks.
I had the job of running in these saws from right out of the box for the competition. I let them sit in my unheated garage for almost a week with outdoor temps of minus-20C [-4F]. After fueling them up I tried to start these frozen solid saws up , it took close to 200 pulls on the rope of each saw to get them running. The last time they ran was at the factory with indoor room temperature. Now trying to be started at these cold temps the carb was set way too lean from the previous warm settings.
I would have saved alot of rope pulling if I would have taken them indoors and let them thaw out first.
Anyways I got them going and each saw I ran at WOT for 5 minutes ripping blocks of wood standing on end into slabs. Right from their first tank of fuel at the competition these little saws put out amazing power for a small saw. Super hyper with the rev boost.
Thanks for the advice Randy, when I buy my own 550XP maybe next week I may just send it to you. But for the 3 I have for the yearly competition I'll just leave them stock. The men and women who torture them for 3 hours of steady cutting in the 10"x10" spruce the power they put out is enough. Some of these people have never run a saw before.If you think they are great stock you would love one with 40% more cut speed.![]()
I think what Magnus has already said here ,is all he needs to say.One thing you should know is that these "learn" or remember last run and runtime in averege.
They adapt after the current conditions they are in, and remember the settings. It is not possible to see what altitude it has been run at, but what fuel settings and carb temp it had is.
I modified one and kept a record of timed cuts in clear poplar. From out of the box stock, to muffler modded, and then on to fully modded it gained 41% in cut speed. Some of that was from it loosening up and the rings sealing of course but ever the less I was very impressed.
Stock
Muffler mod
Fully ported
An example on what elevation does to tune.
I built a MS261 and tuned it to 13,800 at 1900 ft above sea level
I sent that saw to Australia and it was turning 15,600 at a few ft above sea level.
Thanks. Watching those video's comfirms what I was thinking. No way would I just muffler mod the 550 for the gains made to put up with that noise. 550 to me would either be left stock or get the woods port treatment to make the noise worth while.
550 had been the loudest muffler modded saw I have heard so far. Just not worth it for the gains IMO. Your guess of the % you saw in just MM?
That seems to defy expectations. I would have guessed maybe an increase of 1000 rpms at best, based on only an altitude decrease of 2000 feet.
Yes.. temp plays a part as well.
I can tell you from experience... Altitude and temp DOES matter..!
I would love to try an auto tune to see if it will compensate and then remember. But a regular tunable saw.. Fug it.. take a screw driver to work if you want optimum cuttin performance. I work between just under 1000 foot (300 meter) elevation to 8000 foot elevation (2500 meter approx) elevation.. Air temps differ as well as does moisture content. IT MAKES A DIFFERENCE. Anyone that wants to dispute that, I welcome to get their ass out here and try it the fug out.. I will personally pull cutting permits to test the theory if need be.
That is correct it changes regardless of altitude.Magnus, if its corrects based on conditions, then it is accounting for the less dense or more dense air! Altitude! Intentional, or not, it is correcting the result of altitude changes.
Would it agree more with you if someone else said it?"I don't get all this hype about elevation. If you run a saw at one ot 1000 feet above water level is not important at all.
Hight don't matter much as only gravity increase. As long as pump can hack it there is no issue with altitudes.
The air itself, moisture, content, pressure ets, that do affect and do so what ever elevation you are at if it change.
Humidity is what affect most.
Moisture is often different in different heights, but it is not the hight that make the difference.
Setting saws after hight is a ridiculous load of crap that is used as excuse to put blame on something.
When you run saws you notice they act different in different weathers. Humid air need one setting as opposed to dry."
Remember that time you spoke about "altitiude don't mean shit".
Oxygen is less dense with altitude. If the saw adjusts for peak performance because the air is different, then it is compensating for the altitude, whether you like to word it that way or not. Quit being a contrary douche about everything spoken. If you'd listen before you argue, simple things would make more sense to you.
