Kubota R520 cooling problem
  • Replies Replies 68
  • Views Views 4K
Grandfather worked at Letterkenny army depot In maintenance rebuilding diesels. Said they always dumped a quart of atf in the oil a few hundred hours before an oil change. Supposedly cleaned the carbon and sludge out of the block. Used Marvel Mystery Oil in the fuel of everything he owned.
  • #52
So talked to a Kubota dealer service guy who has a reputation for being knowledgable, it seems it is the head gasket. One tell is there are bubbles surfacing in the coolant overflow tank when the engine is idling.
Machine still runs perfect on level ground. Btw, same overheating occurs on a downhill as well as uphill.
I've been dealing with this silly problem for months now, getting super annoying to live in fear of the temp gauge, eager for the dealer to sort it out. The service guy says he will do diagostics at his shop before he does the head gasket job, to confirm.
  • #57
Thx for asking. Yup, brought it to a nearby dealer with a good rep, they replaced the head gasket and some other maintenance items, all good now, although it does seem to be running too cool, the needle never gets off the "C" at the left side of temp gauge, and this despite relatively warm december temps.
Good to hear!
Maybe throw a piece if cardboard in front of the grille, the Alaskans can back the validity of that trick. Less airflow=less cooling.
  • #59
Doh I never thought of that but yeah, simplicity is genius and that raddyater gettin cardboard tomarra mornin
  • #63
The gauge has always appeared to be good. The thermostat was replaced previously in the course of trouble shooting the over heat problem. I wonder if the correct one was used.
  • #66
Yes the needle moves, and today it moved more than usual because the cardboard worked a treat (as Mick and his ilk would say), despite it's sloppy fit, it made a difference.
Thx for the heads up, Kave. I've used cardboard in my chip truck before but it was awhile ago and I forgot that simple trick
So easy a Kaveman can do it...
Internet forums are often the worst place to ask these kinds of questions.
"My truck started slowly today"
"Bent rod, bad injector, possible leak in water jacket, magna Flux the block, post pics"
Or maybe is was cold as a witch's tit in a brass bra...
K.I.S.S.
Keep
It
Simple
Suckerhead.
