Is This Cool? - Rattle Wedge
  • Replies Replies 25
  • Views Views 2K
The ratchet screw isn't designed for heavy lifting, either whole tree or thick hinge.
As Benjo said :
Looks like it would be good for about what he's using it for. Something that is just beyond being able to push by hand but not really worth setting a line for.
mostly for toppling tops or big logs.
I've used one a couple times, maybe 10 years ago. It needs very few room to work and it avoids the hammer, but it's quite a big chunk of aluminum. The main problem is that the screw bites the wood just at the edge of the trunk by very few threads. It isn't really easy to drive in because the torque applied to the handle tends to pivot the screw side way instead of along it's axis. Surely a lack of training from myself but still.
I heard that the owner threw it away because the ratchet part went south, likely the steel wore the aluminum.
