F
fishhuntcutwood
I think it was Gerry's book, and if not it was someone who knows a helluva lot more about falling trees than I do, but I know I've read and accepted to most always make your cut level.
Perhaps in post 13 of this thread?
OK, the answer is, it depends.
Always remember that if you pitch the face out of parallel with the stem, you generate swing to the high side (relative to the stem) of the face. On a side leaner, that will compensate for the gun and generally put the tree into your intended lay. But it also sweeps the top through a larger arc on it's way to the ground, so if you are trying to drop it between other trees, this can be a disadvantage. It also creates a somewhat (who knows how much) weaker hinge since the wood fibers in the hinge do not run perpendicular to the hinge, but rather on an angle.
Forming the hinge perpendicular to the stem gives you a fall that will miss the gun to the side the tree leans, by the amount the top of the tree is off of directly over the stump. But the top doesn't swing through as much sky, and if you aim the face to compensate for the distance the top is out of plumb, then you should hit the lay pretty well. And the hinge should function more reliably since the fibers run true through the hinge.
If you form the face as indicated on the left, you have compromised the potential strength of the hinge since the fibers are not running true in the hinge. It's hard to say by how much...species certainly would be one of several factors in determining that.
If you are looking at the tree in erm's drawing from the south side and are felling it to the north, you have set up a situation where the top of the tree will hit to the right of the gunned lay by the distance the top of the spar is off to the right of the stump, so to compensate for that you have to adjust your gun to the left by that same distance, at the head of the lay.
If the hinge holds well, the top will not swing left or right, but will fall with the tree sweeping through a piece of space as wide as the horizontal spread from hinge to top, and as deep as the tree is tall, all the way through the fell.
If you form the face as indicated on the right, the hinge strength should be optimized due to the fibers running perpendicular to the hinge. Of course, depending on the degree of lean, that still might not be enough to hold the tree on the stump...Jerry described that issue in his post.
The gun should be accurate for placing the tree to the lay, again if the hinge functions well. The top will swing from right to left spacially, occupying the same dimension of space as the first one at the beginning of the fall, but that space becomes a narrowing wedge as the fall progresses and the top comes into line with the gun.
Boy, I don't know if this is an improvement or not :roll:.
It is except in this sentence, don't you mean left?
[quote[If you form the face as indicated on the right,
I've been busy. Some cool stuff happening right now.
