Gear storage
  • Thread starter Thread starter Page
  • Replies Replies 38
  • Views Views 7K
You are quite welcome.
We could follow up with a discussion of the pros and cons of using a petroleum based hand cleanser for working pitchy areas out of a rope, been talked about before.
what about veg oil for pitch on rope, as with skin?
One bathtub is soaking three ropes right now, as it happens. DIRTY. Muddy, wet, clay soil job. Should come out lighter, in color and weight.
Never worked well for me, Sean...and then it was relatively hard to remove that residue itself. But others have reported good results...maybe I'm not patient enough.
You probably don't work with a high enough percentage of conifers for it to be a problem, Mick. Here, they just get stickier and stickier :D.
Burham the worst one was a infected Norfolk Island pine which was entirely coated from tip to tail in sap, every section of trunk, crotch or limb was coated in white sap ranging from a thin skin to pockets thicker than my thumb.
By lunch time my pulleys had turned from inny's to outy's , the cam on my pole strap was gummed to a stop, my prussic had glued to the rope in fact I was sticking to the tree by that point.
Only solution we had was petrol which I had sent up, this freed me from the tree and opened the cam on my polestrap and with another climbing system I was able to descend and then could see why the grounds people were complaining about how the work rope was running by looking at the pulleys.
Never had as bad again but this heavy sap stuck in some slings and rope sections hardened to the point that we threw it out or cut it out of the materials.
Since then I have been wondering how to wash the sap out while it was still fresh and had not hardened yet without using a petroleum based product on the ropes which as a general rule I have been avoiding.
Picked this up this morning from Princess Auto, limited supply special, $89 CAD, steel. Going to add two more hasps and figure a way to secure it to the truck and can be removed (by me).
