Most double braid or 12 strand rigging lines you’d probably never notice the twisting/ hockling on a porty. 3 strand might be more noticeable, and I’m not sure it’d be any better with the Hulk. Your portawrap is a tried and true bomber lowering device. I don’t wanna pass judgment on this thing with nothing to go by but pictures but I’m also not be the guinea pig and buy it.^^^Is that cool? I guess by extension, is twisting the rope especially bad? The portawrap(which I've yet to use) has an elegant simplicity. Are the drawbacks related to turning a rope around a single post worth the complications of more exotic solutions?
It isn't especially bad (on long lengths) with the bouble braid ropes, as long as you keep inverting the entry side on the portawrap or the bollard after each run. Setting the rope around does give the twist, not running it by itself (running actually pushes the twist at the end of the rope's length used at this moment). With alternating the right/left entry side, the twist from a run cancels the twist of the previous one. If you stay each time on the same side, the rope accumulates all the previous twists and you got an unusable and unbearable mess.^^^Is that cool? I guess by extension, is twisting the rope especially bad? The portawrap(which I've yet to use) has an elegant simplicity. Are the drawbacks related to turning a rope around a single post worth the complications of more exotic solutions?
