In the heavy horizontal limb scenario, I will make a series of compression cuts, just deep enough to start feeling the pinch, then come in from the top, stagger the top cuts inbetween the compression cuts, starting from outboard, cut JUST enough to see the limb sag a little bit, come back to the next stagger, cut, etc...
By the time you get to the last cut, furthest inboard, a lot of the tension has been relieved...or at least spread out over a longer distance and the final release is easy. Even if the limb lets go early there are enough compression cuts to stop it tearing down
Face cut and top cut does get used too, depends on the tree.
Any time I do a snap cut I alway do the final cut INBOARD (or at least level) to stop saw snatch. I have had my saw snatched and there is NOTHING you can do but let go.
