Best Manual Air Pump?
  • Replies Replies 9
  • Views Views 440
lxskllr
MD USA
With my flat tire the other day, I found the hose on my punishment pump doesn't fit the valvestem properly. I could replace the hose or something, but it's already had at least five hoses, and it has a broken handle with a hacked on piece of wood. It's also miserable to use, so I think it's time for retirement.
That brings me to my question. I'm currently using a Joe Blow pump for my apta, and I really like that a lot. Once I test the valve for fit, I may get another one for the truck if it works. The problem with the JB is it has a lot of plastic, and looks generally delicate for banging around in a work truck. Is there anything better(rugged) available?
Requirements...
At least 160# of pressure. More is better
Durable
Fixable, especially if it's expensive. Replacement parts that cost almost as much as a new unit isn't very useful
Manual. I like the dependability of using my arms, with no electric, and few mechanical parts to fail
I suppose since I have a Milwaukee saw now I could possibly be convinced a Milwaukee battery pump is worth getting, but it would have to be the second coming or something to interest me over the reliability of a manual pump.
I have the M18 Inflator. It is in a bag with my jump pack and digital multi meter. It'll inflate my rear backhoe tires from 0 to 12 psi many times on a charge. It says max 150 psi. The only hand pump I have is rated at 3,600 psi, but it's very slow.
Here I thought that I was the only person nutty enough to fill up a full sized truck tire with a hand pump.
I've always just bought a "decent looking one" from wallyworld, and I usually get a few years out of them, before they die.
Yet more proof that Marylanders are built different.
Handpumping sucks, but it works. The only thing that sucks more than handpumping is plugging a tire, pulling out an electric compressor, and the motor seizes at 10#. Electric compressors is where the hoses for the pump I want to retire came from.
That pump's about 30yr old. Has a cast iron base, with steel wire footpads that fold down. I got from WesternAuto.
Nah, they've been gone since the early-mid 2000s. The name might be around somewhere, but afaik, they're completely dead.
