the PCW5000 is a solid product, it does weigh about the same as a 5 gallon can of gas so not terribly light to pack into the woods, and it being a 4 stroke it cannot run on its side (which it LOVES to do, its tough to keep it upright)
the little honda engine is excellent, reliable and uses almost no fuel
Pros: portable, uses minimal fuel, can easily control how hard or fast you pull based off how hard you tail the line and wraps on the drum, relatively fast pull for yarding stuff a long distance
cons: heavy, cant run on its side (anchor has to be below the winch and pull it into the ground, if the winch "floats" then it wants to flip over, the solid truck hitch anchor would fix this I think, $1500 price tag is a little steep IMO
