20oz wow. You could try tight wrapping soldering wire(unleaded of course) to get t the wt up to your preferences.
This might help
1. make sure the securing bolt is checked every time you throw. Happened to me the other day after a few retrievals and the line came on done and the RK fell out of the tree and I lost my TiP.
2. I always insert the line through the nose cone and secure to bolt. It takes a bit of practice but really is much smoother way to isolate and retrieve and smooth over the transition/RopeShield
3. Many times I will when attaching the rope to the Rk leave the RK coupled together but release the line from the bolt and pull enough line out through the coupling bolt hole and then thread the line thru the Stainless steeel end or tip hole and then pile hitch the line to the climb or rig rope.
4.Always thread the bolt back into the RS or place it in a pocket, I'm all thumbs so for me anyways it is easy to lose one especially in this snow
5. I let the RK smash around a fair bit, it is easy to refinish with nail polish and fine stone.
6.Keep a quarter with you or in your kit for torqueing down the bolt. Most times I just use a zipper pull or belt buckle
7.I also keep an inexpensive multitool in my kit it has knife, screwdriver etc to open up the tip incase it gets really bad or closes up
8. Best throwline and coil system is the Sidewinder found at Treestuff mine has held up for a couple years now and only needed to repair the handle and snap it back together a few times
9.vinyl sleeve is perfert for throwing over a house if you see that it might fall more than10 to 20' onto shingles. I ahve never damaged a thing so far jsut bruised some decking and shingles, hardly noticeable.
10. for you and anyone around you SAFETy call all clear and never pull on it really hard most times when you feel a jam up it just needs a few jiggles to bump the tip over the obstacle
11 When retrieving, for your safety you can under the tree towards the stem and pull it free. Pretty much every time I have retrieved the Rk will land within a few feet from where I ahve thrown it. It is attached to a line and almost always follows the same path. No what I am sayin?
12.It really cooperates once you get the feeling for the how the line feels with the RK---line. It feels more like the RK is tiny bump of an extension to the line. Feels and acts much different than a throwbag.
13. Throwing it just start low and get used to the weight(as is). I can throw this thing pretty accurately and high to almost 100'. I broke my BigShot tubing again a few months ago and forced myself to throw more and find I only miss the BS when I need to blast thru an understory or thick canopy which is quite often
14. Longgun Technique is killer accurate. One or two hands just find your rythem, focus above the target a few feet and release on the exhale
15. I used to keep a piece of reflective red tape on mine and once it wore off found that keeping it clean and polished was pretty good at spotting in the tree
16. the red vinyl sleeve is really good for spotting and the additional weight is welcome in really thick trees so what I do is throw it hard thru the target and let the RK run to the ground and then slip on the red vinyl and then isolate the tip and drop it thru the crown for a good run of the rope
17.used to keep a bit of crayon to keep the throwline stiff for inserting thru the tip but now I just use spit and my finger. Works just as well
18. you can on the SS tip file down the sides at the holes and connect a mini shackle
19.watch the RS doesn't smack your fingers when you pull the RS with the rope inserted, it slides down pretty fast. I hold the line so it hits me on the outside of the hand/the soft part of the fist where your pinky curls other wise shake the line vigorously
Here is the Facebook with lots pics and vids if you get confused call me anytime
Hope you have lotsa fun and punish the the lil bugger to no end
[image]https://www.facebook.com/pages/RopeArmour/113201298749998?id=113201298749998&sk=photos_stream[/image]
https://www.youtube.com/user/ropearmour?feature=results_main
