Woodworking
  • Thread starter Thread starter Fiddler
  • Replies Replies 567
  • Views Views 63K
My best friend has been adding onto how house for about three years now. His son is the one whose knives I’ve posted pics of. They sawed out (chain saw mill) a timber from which he plans to build a mantle, out of a big pecan tree they took down in front of their house. His son handmade his own tool to work the timber down with.
We have some really big pecans at our farm. I will eventually have some big spars to work with...I'd be curious to see what that fellow does with his.
Would woodturners etc be interested in lombardi poplar? I've got some biggish one coming down soon, timber is just going to a burn pile otherwise.
Pecan is one of the hardest woods to mill in the US. Probably softer than the softest Australian hardwoods, however.
Ah the dilemma of bits on the wood pile!
I had one set aside for branch cone and trunk limb grain wrap...wasn't set aside well enough, the Mr. burned it
  • Like
Reactions: Raj
Sooooo now its time to make new laminate kitchen countertops....not "true" woodwork, but here we are.
Spend 1day prepping the lumber for the edges and backsplash only to be informed she changed her mind, wants laminate (is there much of a job market for an axe murderer?)
Then she wants large rounded corners on the ends...
So first l make a template, 6" cookie so l can make a template to rout a smooth corner on the countertemplate...and buy a new (longer) router bit.
Now we need to pre-form the laminate with a heat gun to get close to the radius....
This is my test piece, l'll glue the strip on and see how it holds.
Oh the joys of construction/remodeling...I miss them not!
Best of luck!
A few things from over the holiday break:
Three of five cutting boards,
A yarn bowl for the second youngest,
Two votive candle holders for Karen, also photo of spalted holly.
The two matching charcuterie/cutting boards were for my adopted son and his girlfriend. (They live in a tiny apartment in a suburb of Boston, so I kept them on the small side. Mottled appearance as that was just after the first oiling):
And I finally got started making the fireplace surround and mantle. Made a mock-up in plywood, with a slab of walnut tossed on top for the full effect.
The finished mantle will be Ash, and the 'ebony' squares in the pattern (as done in the mock-up using a black Sharpie marker!), will be done with thinned, matte-black Rust-O-Leum paint, to allow the grain to show. The baseboard will end around the base of the uprights, and I'll carry just the shoe mould around the hearth. A lot of the Ash for this, the window trim, and the baseboards came from trees I have removed and milled:
That looks fantastic. Kind of has an art deco thing going with it. Looks like something that would have been installed in a upper end city house, circa 1927.
Sexy. what are the dark pieces? Separate wood or stain?
An old-timer told me to, "Use the 'poor-man's' ebony", better known as satin-finish black Rust-O-Leum.
Thinly applied you still see the grain pattern, and it lasts quite well. The window trim squares are three years old now, and no issues.
Spalted American beech. The thing that got me into saws and tree work!!
