Wood hardness help please
  • Replies Replies 8
  • Views Views 1K
davidwyby
Rural desert logging
SE CA
I don't understand tamarix numbers. Janka is how much force it takes to shove a ball into a piece of wood. I'm not sure it's a trivial calculation to covert from mm² because you have to calculate the area of a sphere with a constantly changing radius. I don't think the force is going to be linear.
Simple math with Google doing it for you. Convert Newtons to whatever, and convert square mm to whatever. Just know that if you change the surface area units, you need to proportionally change the number such that it still matches the same pressure at the original surface area.
Don't over think the sphere, it doesnt matter unless you plot force vs depth. Otherwise it's just like PSI.
I don’t really consider cottonwood a “hard” wood but it is certainly a tough wood. Lots of heavy equipment haulers like cottonwood for trailer decks in my neck of the woods.
It's not simple math, and I don't know that the author of the tamarix paper knows what he's talking about. A mm² isn't a sphere which must be used to be a janka test.
Just running straight math, the janka test has a final surface area of 100mm², so that would be 33.7*100=3370. That's way past the cottonwood estimate.
edit2:
I found the full study, and they have a chart that compares it to ash. Might give you some idea of what you're dealing with.
edit3:
and here's the wiki on janka hardness. White ash shows up, so you can run the percentages and see what it falls near for something familiar.
If I did the math right, you're in this general area(3363)
edit4:
LoL! I'm looking at it, and that hits close to the straight math. Your cottonwood estimate off? If straight math works with the study, I think they may be misusing the numbers. I don't think it's appropriate to change the janka readings to mm². It could very well be that 1mm² is easier to push into the wood than a 100mm ball due to side pressure on the curved surface. I'd like to hear from a material scientist on that.
It's softer than cottonwood, which usually has a Janka rating of around 350 lbf (1.56 N/mm²). Tamarix wood is typically used for landscaping or fuel, but it's not known for high structural strength. How are you working with it—processing it for a particular purpose, or just managing the trees?
  • #8
Welcome to the house.
Removed a bunch of them that were a windbreak that was left for decades and got out of hand. Some pretty big. Just want to make something from them vs. dumping. Customer dumped most of what was removed in the river bottom to slow erosion.
