Sean no mine is different. Install pull rope. Make a horizontal cut 99% the way thru, put a wedge in to stop the cut closing, finish off the cut at the back, with a small step, now the piece is just being held by that step. Cut a face in the desired direction of fall, no dutchman or the likje. Have the rope pulled, (Or use a felling bar, or both), the face closes and the piece pops off.
Gonna add the magic cut the memory though, thanks!
I AM with you on that Ben..
When there is often no need for the control of a hinge, why make one to have to fight..
I do it a little differently..
Cut the top cut of the face first, deep and only a slight angle.
then on the flat bottom cut of the face, bypass the top cut and just keep cutting straight back until the piece starts to settle.
pull out and cut the remaining strap on the back side.
at that point the piece will either just fall into the face, or you can put the saw away and easily push it over.
Its fast and easy.. Since there is no hinge, there is no need to worry about a bypassing the face cuts. A little bypass is actually intentional, just to make sure the cuts meet.
Once you get the rhythm down, its easy... 3 quick cuts and the piece just falls into the face..
the face can be very narrow, 15 degrees is plenty.. once the piece starts, it just keep going
Others do similar cuts. Its been talked about before..
