Burnham, do you really mean that using wedges on trees that small would be better/faster than using a long felling bar?
I've spend a large ( way too large actually, it's not fun work) part of my youth thinning trees like those for pulpwood.
Usually a stand of trees will have a common lean, maybe only a degree or two, but still enough to utilize when falling them. Start at the point they are leaning towards and work away from there.
I figure you can knock a conifer of up to 1½ cubic meter( can't do boardfeet, sorry) over with a felling bar if it stands straight, bigger if they lean a few degrees.
The added advantage of using the felling bar, is you have it on hand, whenever you hang a tree up.
Like Bermy said, using a splitlevel cut will help those without total control of the saw cutting into the bar.
. It's not a tool with much history for use here in my part of the world...I expect because for most of the history of logging here the trees were far too large to use a felling bar on.
