sawinredneck
I cannot stress this enough, the new gas SUCKS!!
I've got a job tomorrow, doing some welding and I needed the mini to load the welder. I dig a path to get it out, fire up the mini, first time in a few months, and back it out to move some other stuff. Drive it around back to take off the bucket and put on the forks, no problem, then it dies! Fires right up and keeps running. This went on for a while and just kept getting worse and worse! I got so mad I swapped out carbs, same issue!
I checked everything I could think of, fuel shut off solenoid, power to the solenoid, fuel to the carb, nothing out of the ordinary!
I managed to get the welder loaded, took two hours to do a ten min job, but got it done! I called my dad out of frustration and he and I got to talking. After going through what all I had done he finally piped off "You've got water in the tank and have filled both carbs with water now!" I drained the tank and damned if he wasn't right!
So this is notice to the rest of you, run a fuel additive or what ever you need to keep the gas as fresh as you can now days!
