Tracked Chippers in the USA?
treebogan
bergen, Norway
Do you guys see many tracked chippers?Almost everyone here keeps the chip,so driving the chipper to the brush makes sence and saves time.
Here is a picture of my chipper and one of the trucks.
(it dosn't normally ride this truck)
The track frame extends width wise so you can fit the machine through many gateways.Here it has the tracks withdrawn to underneath the machine body.
I've pondered adding a powered undercarriage to mine so I can load it into the trailer and save a trip.
You can buy the tracks with hydro motors, but they'd be like $6k and you still have to build the sub frame. I was thinking of building a skid (like a skid steer) undercarriage or using a pair of driven steer axles.
So far I'm not doing anything. I am wondering if a Boxer mini skid would have enough push to load the chipper. Another idea was to mount a winch in the front of the bed and hoist it in.
Or you could just stop trying to re-invent every thing you own, and buy a track chipper...
  • #13
They are pretty good in the right places,easy to train a person to move around etc.
They also are handy for tensioning Zip lines.
Mobile Chippa
We love our Track chipper so much that currently I am building a 36 inch model to fit through gates, as our Bc1000 is like 5 ft wide. Check it out on our services page, www.treecycleseattle.com
  • #16
Didn't know that Vermeer made a tracked unit!
What machine are you using to base the smaller tracked machine on?
I believe all the large chipper mfgs will make them on tracks. The only problem is it adds $20-30k to the price.
My hopeful plan is to buy a 18-20" chipper next year, assuming the way I currently handle debris stays the same. It will most likely be too wide to haul it in the trailer, but we'll see.
Thanks Butch, the name is Cut, Money Cut that is.
Vermeer does make a tracked unit but it is huge and Mucho Deniro. Instead we took almost a brand new BC1ooo and scrapped the axle in favor of an undercarriage from a tracked excavator( 6,000 lb machine). The hydraulics run right off the Cummins and it has really been a time saver . For jobs down trails or along green belts it actually makes the job kind of fun.
For our small chipper I am basing it off a Morbark Eaver Beager Drum chipper. On top of a stump grinding drive system so it won't mess up the turf, Thanks Money Cut
  • #20
That sounds really good.What would be really nice is to have the extendable trackframe from a mini excavator complete with the slew ring.Then you could pull the width in to get it through gates and then extend the frame outwards for stability.
Being able to slew chipper to face the brush would mean less moving it around.
A guy here had a Bandit 90 made onto tracks, it cost between 60-80k and it's still a 9" chipper. He got rid of it I guess after going through 3 remotes that Bandit could never fix.
I've thought about the idea, but I don't think I've ever said "I wish I had a tracked chipper". Except this winter on a clearing job I did. If I can't move it with the truck, it gets moved with the mini, and if I cant move it with the mini, it stays where it is. The location of the chipper from the work reflects in the job cost if it's that big of a deal.
You can do alot for $30k. Brendon found a place that sells the whole track setup for $6k a pair. I'm pretty sure I can build a frame to hold them to the machine for less than $20k. Hopefully I could get the hoses and 2 spool valves for under $4k ;).
