pantheraba
More biners!!!
I felled this dead pine solo yesterday, about an 80 foot pine...it was pretty vertical, slight side lean. I put a re-directed pull line into the top 1/3 of tree...shot a line with APTA and choked the top. I used a 3:1 hoist to put a good pull on the top...hoped to break the top out of it (there were some other deader pines down the lay from this tree...was concerned about a domino effect that would hit the neighbor's fence...managed to miss the domino trees). No breakee so used that good pull to help the fell.
I wanted to be sure my bar could make a complete sweep towards the hinge (not in Denmark here, Stig) so I shaved off the side bark.
I also did a vertical bore from the back cut side to get a feel for where good wood started...it was about 3 inches in.
I gutted the hinge thinking I could do better pulling with my hoist line against two posts rather than a full width hinge. But once it was felled and I checked the hinge I saw that the right side of the hinge (from the back cut side) was more rotten than the left. Seems to me that gutting my hinge sacrificed some good wood in the center that might have been important.
It did not cause a problem but...maybe it is better not to gut the hinge on a suspect hinge?
Note: that red ABR ULTRA RIGGING BLOCK 5/8" SLING is not from TreeStuff...it LOOKS like it is. My friend, Luke, good friend of my son, Alex, has been working with us some to learn tree work. He borrowed my Toss wands awhile back to practice splicing...and has borrowed some gear from me (he is one of the three people that I will let borrow my stuff)..and has started cat rescues, too...I recently had some cat rescues that I could not go to and he took over..and did a fine job.
To show his thanks to me he made that sling for me as a Christmas gift...how cool is that? This was my first use and it worked very well...THANKS, LUKE!
(he lurks here...he will eventually chime in...)
