dstimber
Maple lumber is my favorite! No telling what the grain is going to look like in them. Beautiful stuff imo.
Jed the 562XP is bone stock. I also got a 550XP that cuts like a raped ape! I gave up on hot-rodded saws a long time ago. If it don't kick ass stock it ain't a good saw.
Well, I'll be damned.
We actually agree on something![]()
Jed, somebody has to be the asshole around here.
Guess it is my turn. ... ...
Or maybe like somebody, not used to running a bar that can't reach all the way through, was doing it.
Hinge is way thicker in one side.
Now tell me that was on purpose, to compensate for lean, and I'll shut up, pronto![]()
Sap filled fat wood center held while crispy punky paper like outside popped. Under tension from skid steer. And not over tensioned. Just did it. The consistency of the different hinge woods caused the failure. Probably should have gutted it, but I was afraid the side weight would pull it to the out houee. It had a large sweep in it too with back lean.
You might try this, works for me.First start from sitting overnight is not usually the problem. It's after I've run it for a few cuts, then turn it off for 5-10 min, then try to restart. Whether I choke it or not on the restart attempt, it flat won't go,even with a dozen pulls. I have to hold the throttle on full and pull about 6 times to get it started.
