Nope. No solid matter. Dissolves with solvent. Tarry. The desert with CA fuel is different…I think the green goo is algae or at least the result of it
 As you can see, these trees are in great shape. I have a light hand!) I have not seen a single tree that has died after my work. Max light hand!)
Not tree work but somewhat unusual. I had a malfunctioning jet pump and pressure tank. That was also in the way of a waterproofing contractor. Replaced the jet pump and pressure tank as well as the drop pipe for the well. Relocated all the equipment to facilitate the waterproofing. The interesting part was the well. It was 12 feet total depth and had a 3 foot water column in it. A total volume was just shy of 160 US gallons. This was a hand dug, stone lined well. I’ve never seen one like this. They built the concrete bunker around it at some point. The home was about 100 years old. There is a creek that runs through the property at the bottom of the hill. They probably hauled all the stone for lining the well from that creek bed.
All professional Stihl saws have anti-vibration. The question is probably about a small Chinese saw. This saw also has anti-vibration. Otherwise, I wouldn't have bought it. Do you think the Echo CS-2511TES has an anti-vibration system? So, this little Chinese saw is a clone of this saw, with some differences. But in general, this is a very successful mini-saw. For just $170, I didn't expect this quality.Max, does your say have anti vibration handles? From the pic, it doesn't look like it. A 201 for example has AV /antivibration
