Gorgeous green Euc. Quite springy not too stringy. Council axe got stuck. X27 not too bad. OxHead was the best.New splitting axe!
I did the same, got it stuck, handle grain orientation was wrong, broke it. Lee Valley replaced it. Old one I’m gonna put a 36” handle on.It's a nice axe. I got one a year or two ago. Handle's very comfortable, but I'd prefer it was hickory rather than ash. I've already boogered it up taking on bigger wood than it could sensibly handle.
I nominate Stig for most considerate, open minded boss.she asked if it would be ok to work in a sports bra.
I told her that for all I care, she could work topless.
Thanks!I reckon that the curved leader (hard leaner) that I see in the background could at least use a triple hinge, Maybe a dutchman on the far side/ tapered hinge or a chunk of wood in the facecut, and more likely a 90 degree retainer line (guy line).
I'm thinking wide open tall block face (whole face a sizzy) (the one I felled wasn't as open as I'd like). High back cut. Face and back cuts 90 degrees to the trunk vs. horizontal, maybe even higher opposite the lean. Triple hinge or shark gill or whatever (this might make it too hard to wedge over). Angled hinge, more hold on the top side opposite the lean...maybe triple just up there. Then a high back cut. I think a dutchman or chunk in the face will just break the hinge too soon. Gotta get it started in the direction it needs to go. The question is if it will go far enough before the brittle wood breaks because then gravity takes it. As long as it's past the fence.... :-D I have forced salt cedars 90 to the lean with wedges, one big tree was successful and a couple smaller half successful. They had crown weight that this doesn't though. The easy way would be pull 180 to lean but where's the fun in that?I reckon that the curved leader (hard leaner) that I see in the background could at least use a triple hinge, Maybe a dutchman on the far side/ tapered hinge or a chunk of wood in the facecut, and more likely a 90 degree retainer line (guy line).
That would be quite a cut to seeA full-gap face can still have a whizzy added, and a triple hinge.
Prepare to be amazed. 🤣That would be quite a cut to see
Yes…but first the rounds will be benches for a wedding. :-)Firewood for days there!!
Valuable (and more stable) wood like mesquite I paint the ends. I haven’t done enough green Euc to try yet. Most say it’s impossible to not check. Just gotta avoid the center/checks. I will try some of this lot…paint, cover, store in shipping container. Sealed one if I can, maybe with water in it to slow the drying? The thing with the desert heat is it dries stuff fast so that it cracks but if you keep it moist it molds. That one had checks showing in the ends of the logs from the drive home.Are you end-grain sealing with Anchorseal/ similar or paint, asap?
Get it in the shade?
