Stihl top handles
  • Thread starter Thread starter Al Smith
  • Replies Replies 53
  • Views Views 10K
Got the carb kit today and it's for a Zama, I've got a Walbro. The Walbro has no high speed jet, how the heck do you tune the dang thing?
The Stihl experiment with fixed main jets was an abysmal failure. Buy a replacement carb that is NOT a fixed jet model. either pull up your IPL or else go to the dealer and scroll through and find an older or newer carb number that is fully adjustable.
The fixed jet carbs can be tuned by opening them up and replacing the jet with larger or smaller jets, but they are $5 each and usually special order. Completely worthless. :roll:
  • #28
You don't ,just set the idle .That's all you can do . Fixed jet carbs were made for one purpose--so you can't burn up a saw from running it lean .They kinda suck .
Yeah, I was thinking I'd go the replacement route. Fixed jet seems to big brother like too me. As well as totally freaking retarded.
  • #31
Actually a lot of manufacturers used them at one time or another .Poulan Stihl ,Homelite .Even the classic 125 Mac had a fixed jet on a few . They didn't work well at all .
In more modern times they tried to eliminate lean run and EPA issues by using limiter caps instead of fixed main jets .Thank heavens those can be bypassed .
so i built 1 saw from 2 last night. put some gas in and fired it up and it idles really high. so i screwed both carb screws all the way in and backed out 3/4 turn. still really high idle. my guess is airleak but i wanted to run it by you guys and see what you thought
Do you have the Zama or the Walbro? The walbro does not have a high speed jet. Here is a pic showing the idle screw in the base of a Zama.
thats not the one i have, lemme go grab a pic
That's the walbro. You only have low speed jet and the idle jet. If you can't get it to idle with those two screws, you'll have to talk to Al.:lol:
Single screw is a fixed jet carb, you can only adjust the low speed.
2 screw is adjustable on both ends, make sure that your butterfly is closing, and that the idle screw is not into far. This is the screw that controls how far the butterfly stays open.
Check the trigger movement and make sure it is smooth, remove the air filter and watch.
I have all the settings in a book down in the shop for all the Stihl products, depending on the saw the settings can range from 1/4 to 1 1/4 turns out from the seated postion. I can double check, to make sure if you like.
OK, no problem, I'll get the info in the morning and let you know.
  • #49
Rocky found this little tid bit .
If for some reason the butterfly gets turned the little slot becomes misaligned with the idle jet and they won't idle .
Willie, the bigger bottom screw is the idle stop set. It doesn't affect mixture at all but it holds the butterfly open to increase idle speed. If you have it set at 1 turn out from bottom then it's wrong and will force the saw to idle too high.
And I told you before not to use that stupid carb with the fixed high speed jet. It will eventually cause problems.
As a refresher, here's the carb adjustment page again.
http://www.madsens1.com/saw carb tune.htm
