rskybiz
Tag sale found a ms280 found its issue, keyway broken all but the very outside. Curious if I could potentially file out a slot for one on the flywheel? Or any tricks to make one stay? Or what may be compatable?
The key is to guide only, it holds no force.
If it is really clean no tooth paste or anything else is needed. It will hold good when properly tightened.
If the fly wheel is properly tightened and sit as it should nothing happen.Magnus, you don't think that a key makes any difference to the flywheel possibly turning on the shaft, if the brake is suddenly engaged during high rpms?
