FJR
Great post Burnahm. When it is all boiled down, it is a matter of the right tool for the job, and that job is dependent on many variables for each person on this board. There is no one size fits all solution.
Jed, you haven't been reading very closely for a good number of years if you have any doubt as to where I stand in the short/long bar discussion. Stig and I have engaged in very friendly teasing for some years now. Bottom line, I'm with Jerry.
But here's the thing: when Willard says we long bar boys would look silly and be slow using 30 inch bars in his stands of 16 to 24 inch DBH, he has my complete agreement. In fact, he's being silly himself to suggest any of us long bar advocates would do so. I know I would never chose to mount a bar half a foot longer than any tree I'd ever see, and I seriously doubt Jerry would either. There would be absolutely no advantage to doing so.
That would be like me always cutting with my 084/60 inch bar combo in this part of the world. And I promise you, that would be as absurd as it would be painful!
The point for me is not whether the bar is long or short in and of itself, but whether it's long or short based on the diameter wood you have to fell and buck. For the bulk of my work I run a 460 with 28 inch b/c. That means that for at least 50% of the cuts I make, the bar is some bit shorter than the wood is across. Not lots shorter, like Stig does, but still demanding the skill and technique to do the job with that limitation.
I also always have on board my truck the 066 with 36 inch b/c. I use that when it's appropriate and as often as not, that combo is shorter than the wood is, too...because as much as possible I use the right tool for the job, for me. And that isn't based on wanting to sport the longest bar my saw can pull.
My saw box also has the lovely little MS200 rear handle, with 16 inch b/c. I use that a lot clearing blowdown wood from roads, and I happily pull it out in favor of the others unless the task at hand exceeds 20 or so inches.
In my mind, I'm not running "long bars", I'm just using the bar length dictated by the size of the wood I deal with, choosing to achieve my goals with less futzing around by having saw/bar combos that get close to those sizes. That does mean I limb and to some extent buck with longer than needed bars, but I don't bend over as much and have better reach than a short bar provides, too.
And no matter what Stig says about the Alps, I still maintain that on steep ground a cutter is better off with long bars and 3/4 wrap handles, most every time![]()
Sure, Stig or Willard or Ed (and a dozen others here I could name as easily) could and maybe even always would choose a much shorter bar for the same tasks, and I admire the skill it takes to do so efficiently. But that ain't for me...and I wonder if those folks shadowed me for a while, if they wouldn't shift a bit in my direction.
Well said Burnham. I'm not ignorant to the ways in the PNW, I had opportunties to fall on Vancouver Island for IWA unionized Macmillan Bloedel. The PNW was a great place to visit and compete in timbersports but I was comfortable logging for a living in Manitoba.Jed, you haven't been reading very closely for a good number of years if you have any doubt as to where I stand in the short/long bar discussion. Stig and I have engaged in very friendly teasing for some years now. Bottom line, I'm with Jerry.
. I've never ridden in a crew crummy out to the woods or returning from that didn't feature some of that sort of entertainment to pass the time. Same sort of vibe here in the House, for the most part
)Burnham I quickly edited how I said differences, but not quick enough before you read it.Lets have pride in our differences and share our experiences with others. Thats what makes the world go around in our wood cutting universe.
Willard![]()
Well said Stig.I found myself thinking about this thread today at work.
I was thinning a very dense stand of 60 year old beech trees and my main objective was keeping them from getting hung up in each other. I did hang one, but also managed to unhang it with no big fuzz.
I was making very low angle facecuts and boring as much of them out as I dared, So the hinge would break fast allowing the tree to rotate into the lay. Some trees I'd aim at others in order to have them bounce off and go in another direction.
Like playing billiards with trees.
A completely different game from loggin those superlong stems in Burham's PNW where the object is to keep them committed to the lay as long as possible by means of a full hinge and a wide open face.
Or Jerry's monster trees, where the main thing is to get then on the ground without them blowing up into splinters.
Or Willard's frozen boreal forests where branches and tops break off and hinges don't hinge worth a darn.
We work in such different conditions and have to jump through such different hoops in order to accomplice what we have to do: To get as many trees on the ground in one piece, safely as we can in a day.
It is great that we have a place to hang out together and discuss these things and even better that we are able to keep that discussion light and friendly, even though fallers notoriously have big egos. ( otherwise we'd have stuck with setting chokers)
The short/long bar discussion is just a way to pass time and learn from each other, nothing more.
Willard.![]()
5) Willard. You've probably been asked this way too often, but do hinges even work in that type of cold?
The monster trees were far and few between.
Were I to venture a guess that statement would apply to 95 % of the cutting in most cases no matter where it's at .--and of course the word "monster" could be determined as being relevant as well .
