A#1:i'm most home at the house;and have no problems here, wish i could do better.
For me this rig was partially born from a short butt tie that would assist main rig in ushering hitchpoint under the support point for gradual low impact release.
>>or actually before for cleaner pull away
>>transfer to main with less slam into line
Then the hinge fiber became my temporary, expendable butt tie to position load hitchpoint almost under support
>>The further out hitchpoint gave more reach across, better balance to any weight transferred to rig line
>>then saw self tightening aspect of using leverage-able length down to stretch rope on own.
Eventually inverting usual problem of not enough tension and impacting on catches etc.
>>to too much tension, must depend on predictable relief, always drawn tite so low impact.
also turned length to friend for reach and tightening to the tension
>>can stash about half of length above hitch point with technique.
>>Factors usually fought could now capitalize on!
Always a game changer if you can play it either way!
Especially high up can fight lots of elastic length in rope in drop to ground control to tighten/self-tighten..
These were my fave for many other things but also very much so for this more immediate restriction needed to force line tension high with less movement.
Remotely install, remove, tighten the high friction with much less elastic length to take hits but also least amount of prestretch needed to self pre-tighten.
Top row of pix can give more balanced loading ;
i used especially bottom half of pic on many things.
3 half rope circles of friction close to load, least amount of line to high friction.
>>Break to only 2 half circles and bend between them holding control side half rope circle locked
Tighten by remotely 'sweating'/'swigging'/leveraging line tighter and quickly passing a 'purchase' to the control side and 'making fast'/'hold fast'(secure).
>>'old sailor terms of rope handling'
>>>>(i like them because shows so much force of intent from those that depended their lives to simpler ropes for millenniums).
The high frictional support(2nd pic row) leaves less tension ed pull on control leg
>>Thus support is less loaded
>>but then also less dynamic length for shock absorption >> less pretighten needed
capitalize on your strong points from the rule set,forge against weak points/leverage-able against you
"Nature, to be commanded, must be obeyed" -Sir Francis Bacon
Rope tight as iron, can be leveraged like iron. The leveraged return is in the tight resistance being bent.
>>iron has tight resistance at room temperature, rope needs to be tightened for tight resistance.
>>Rope can give leverage and interior structure, forming easily (unloaded) without having to heat to 2000degrees like metal.
