As I was driving up my narrow cliff hanger driveway yesterday, I tussle with 'Buster Brown' (UPS guy). He was coming down and I was coming up w/chipper.
Any how he left a big brown box on the porch.
Major changes are subtle, but profound.
Top fairlead is 5/8" rod stock.
The side fairleads are heat treated for stress relief and the pins are set in such a way so the loads are sheer loads. Which means that they can take an incredible amount of force. They may distend under loads exceeding the WLL.
-Can't stress enough the requirement to always use a guiding block set above the unit.
Someone here mentioned pulling/winching off the side fairleads.
This is not what the unit is designed for, it is dangerous, and is an improper use of the device.
Please don't do that. Use a block set above the device which will guide the load line into the top of the device.
Also anyone owning a GRCS needs to have the DVD titled 'Safety First'.
This DVD explains how to operate the device, how to maintain the device, and explains advanced uses of the device.
The DVD can be gotten from Gerry Baranek by emailing him or going through his web site:
www.atreestory.com
Or contact your vendor for the GRCS and get it from them.
Because of folks using the side fairleads in winching operations, the side fairleads have now been removed in an effort to stop this improper use.
Both sides now have the upgraded pigtails. The pigtails have been oriented on the base plate to better facilitate rapid slack removal, and to ensure that no matter what position the operator is standing in, the rope will be at an optimum (most favorable) position for working.
I will have more to say, and additional pictures, in about a week after using the device on the job.
I also welcome anyone to cross post to other web forums. Or, to ask me anything about it. I will do my best to answer correctly.
Thanks
frans
