New Square Chain Grinder
  • Replies Replies 34
  • Views Views 991
lxskllr
MD USA
Was checking out stuff at baileys, and saw this...
Not something I need, and it's *spendy*, but it might be of interest to the right person.
  • #4
For awhile I was seriously considering trying to learn to square file, but I cut a lot of dirty stuff, and I also have issues with sticking the bar in the dirt. The work and frustration potential got me to quit the idea. Almost 100% semichisel chain, and a round file works well enough. I wouldn't mind trying someone else's square ground climbing saw though. No dirt to stick it in, and it might hotrod something like a 2511. Do they make files for lp chain?
Are you using a tripod to stabilize your saw when cutting near the ground, meaning two hands and a rest of the powerhead against the thigh or knee?
It's more bucking. I do a terrible job estimating my depth, and I'm into the dirt before I know it.
While bucking, I sometimes have the bar vertically, skimming just off the dirt, watching chip color (looking for bark). I "set the depth" next to the log to know how to stand/ hold the saw to barely not hit the dirt.
If your cutting horizontally, as you progress downward, you can pull the nose back into the log, cut down a bit, then push forward. You can feel the lessened resistance as you hit bark, then air, barely protruding with the nose.
Don't know if they make a square file that size, but I do know that flat files can be had that'll work for such.
It’s pricey for sure, but by the time you buy a Simington and add all the aftermarket parts it’s close enough to this price to justify it, and I don’t think as nice IMO. That thing looks impressively built. Think I’d actually prefer it over a Simington, even at that price, but my ground guys are hard enough on chisel and semi, guessing they’d wreck a square as soon as you handed it to them.
Thanks for the heads up, didn’t even know they existed.
There’s a guy on YouTube that hot rods saws, a timber feller on the West Coast, hotsaws101. He square files 3/8LP and I think he may be the guy that’s even done it on 1/4P. Not sure I’ve ever heard him mention a grinder, could be wrong. Might check his channel out and see if he hand files or grinds.
Faster yes…also smoother. Takes less power to pull. Square skip is how west coast guys pull those long bars. Also side cuts really well, good for correcting felling cuts. Can be sharpened to angles that are less delicate.
Cons : can cut crooked if you dont pay attention
Harder to sharpen
Dulls faster…than semi chisel for sure. Round full chisel could be close depending on how they’re ground.
I mostly run it on felling saws for clean wood.
