RopeArmour
I wouldn't expect a GRCS owner to switch to a stein.
You might be surprised. Looking for a light weight, less expensive alternative to the Gcrs and something better than a porti.
I would definitely buy another device. Probably not one for lifting, but I would love a better device than the port a wrap when it comes to lowering and pre-tensioning lines. But it has to be fast and easy to set up and use.You might be surprised. Looking for a light weight, less expensive alternative to the Gcrs and something better than a porti.
:eek:To easy
Agreed
Not saying its better or worse than a portawrap, but our 2000 device is an alternative of sorts. 2000kg WLL. 3" barrel diameter.....and is designed to utilize two positioning slings. Bottom is the load bearing anchor, the top is to keep the device upright at all times, so not flopping about as was your earlier complaint with the portawrap. Just a thought.
View attachment 57996View attachment 57997
Bigtwig, theres no flex in the reciever. There is a slight gap so the winch slips in and out easy....but its not going to bend under load. Thanks
I'm not sure to be honest. I never think about that sort of thing. You can carry it all with one hand, if that helps.
Isn't that the Karl Kuemerling (sp) ratcheting bollard?Interesting concept reg. good luck.
I wish they made a mini hobbs of sorts. Smaller drum, ratcheting, and lighter. It would work for most day to day tree ops. I havent strapped the grcs to a tree for lifting his whole year.
