Old Monkey
- Joined
- Mar 9, 2005
- Messages
- 8,767
This thread title has me jonesing for those little donuts for some reason.
When you cut a face all it takes is two cuts!
Whether you do a traditional or a humboldt or any other variation, it only takes two cuts to complete it, not a lot of fussing around and filing away at the bottom of the cut to get it right.
Stig, all good points. But as Jay points out, a high level of caution is appropriate when working near high value targets like houses, so in these cases, isn't checking the opposite side of hinge OK when setting up the hinge on a plunge cut? One of the reasons for a plunge is to get the hinge exactly the way you want it ahead of time, without time constraints, as opposed to "playing the tree" as it is going over when using a conventional backcut. I can't imagine not checking the far side when plunging in a residential setting, but I can imagine it in the woods when plunging to avoid barber chair on heavy leaners.
You need to work on your saw skills, before starting to show us all how to do stuff.
I have been training fallers for the past 1½ decade and you are doing two things that I would not expect to see from anybody but a raw rookie:
When you plunge/bore cut and face your backcut up to the hinge you don't walk halfway around the treee to check where the point of your bar is ( at 1.36 min. in the video).
A trained faller knows where his bar is at all times and doesn't waste time on checking.
I would tolerate neither of those things in an apprentice after their first ½ season of falling.
I realize that saw handling is not so necessary in arborist work, but when someone posts "this is how to do it" videos, I expect them to at least master the basics in using a saw.
