T
TheTreeSpyder
i think that the sap of a pine seems more conductive than water based trees(?); whereby they seem to call lightning to them easier (more conduction to ground?).
We've had many pines next to oaks down'ere that the pine always gets it. Sometimes hitting at the base of a driveway, into the pine, and running the rebar in driveway(popping out pieces of cement here and there) into the garage and the subsequently the fuse box.
Binding is great, and can be done on both sides of hinge. i think this fortifies by pressure, and maintaining alignment/not allowing shift. But still, hinging over by cutting through cracks (especially pairallell to hinge) can give unexpected results. In a solid tree, you have compression and tension. But, in cracked; you can have like 2 individual plates, each with compression and tension.
