murphy4trees
There isn't much to it .Walk the bar around,put a cut vertical where you want the wedge to end on both sides,cut the felling cut .Come up about 2" inches in back make the drop cut ..It will pretty much follow the hinge .It will fall over weather it's level or not .Just don't let it fall on you .A wedge or two might help at times .
Al, it must have been so very long ago that you started dropping trees (was Kennedy president?) that you forget how its not so easy for beginners...
