Dave Shepard
Square peg, round world.
I have a manual transfer switch. As mentioned, eliminates the possibility of a mistake.
Very true...so long as one never makes a mistake. I for one recall a thankfully very few but remarkably dumb things I've done that I knew full well not to, but somehow screwed the pooch. It happens.That there main breaker works both ways. When ON, it brings power IN....and when OFF, it prevents generator juice from traveling OUT.
Been running that way for YEARSI still can’t figure how a manual transfer switch would add anything to my system. I flip the main OFF...the feed beaker ON....crank the gennie and away we go.
I can see a mind twisted for some reason, easy to do given the right circumstances, can do the manual transfer backward. Like, first start the generator to warm it a little before use, plug it in to see if it actually works, then cut out the main line (even maybe not if the "switch on" leads to a mandatory /urgent thing to do/care of). Zaaap!I still can’t figure how a manual transfer switch would add anything to my system. I flip the main OFF...the feed beaker ON....crank the gennie and away we go.
why the outage Burn?
darn...good that you have it all squared away and have planned!Sorry to be slow replying, Austin...the power went out again just as I started to write a post, about 8:30 last night. Went to bed . This morning we ran the genny for 5 hours, then again starting about 5:00pm. Power came back on half an hour ago. Used a third of a gallon for those 7ish hours. Has not used a drop of oil, and the oil is clear as new.
Outages caused by lots of ice and snow and wind and rain. Last I heard this morning, over 300,000 customers without power in NW Oregon.
