Firewood
  • Thread starter Thread starter Ed L
  • Replies Replies 824
  • Views Views 114K
Maybe Kevin cut4fun or whoever was fixing saws could help. I assume ripping at an angle, like a mix between a noodle and rip cut, would cut faster than straight across ripping.
Thought of a previous post when I found this today.
Thanks for posting that, everyone’s got a multi-meter. Curious why they added ash to the “super dense woods” that need a diff reading?
The USFS pdf link came up dead but you can get the paper from the Wayback machine:
http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr06.pdf url into Wayback machine, I used circa 2012
edit - turns out a frustration of mine, that you can't save a copy of above pdf, is due to terms of use of wayback. But you can save it one page at a time or go command line kung fu on it in linux
This load followed me home last week. Standing dead red oak and dying, damaged black cherry. It all had to come out of the back yard short because of the obstacle course path we had to follow. Boss doesn’t like to run shorties through the processor because it’s a PITA to load them. As much as I don’t really need more wood at the house, I couldn’t let it go to the dump
Not too big, easy handling. An Atom Splitter would make quick work of that.
So would the eastonmade 22-28 with box wedge and pull back arm if it was not 2 months late getting here. Latest response told me March 2nd was my completion date. Only 14 months from my order date. I was originally told beginning of January 2023. Then it got bumped up to the end of November/ beginning of December 2022. Now it’s two months later than the original guesstimate🤬. I’m trying not to get grumpy about it, but it is rather frustrating.
Me too, if you guys are talking about building one. I'd want a second ram on a guide, but detached from the log push plate, so if one ram isn't strong enough, then second can be used to force wood through the extruder knives. Elm will have no choice but to become perfectly shaped pieces of firewood in a short amount of time.
I'm not thinking of building one at the moment, I'm pretty swamped as it is. I honestly had no clue how much something like that goes for. It's also one thing to build one for yourself and a whole nother thing to start selling them for profit, and honestly i really don't have a need for one. I helped a buddy build his splitter, and he lives next door :lol: I think it's got a permanent 4 way welded on it, and has about an 8 second cycle time, so you can pile wood up in a hurry, that one you guys got must be ungodly productive.
That said i haven't borrowed it, I've been hand splitting. Yeah I know, but since I'm feeding a little insert I'm cutting the cookies short so i can feed it better, and then rather than picking it up i just smack it a few times and it's all over. No picking up or moving heavy stuff, split right where it lands and only touch it when it's firewood, which suits my back a bit better. The loading arm setup removes this problem, since my buddy's splitter is lacking one I'll have to resort to using my chipper crane thing to try and save my back when i finally borrow it.
I took one of those stupid heavy monster mauls and cut the short handle off and welded on a really long one, I'm talking medieval executioner long. With a lazy round the world swing the short rounds sitting on the ground don't fight much at all. The overkill weight combined with the long handle really do all the work, you simply guide it. Production? Nah but fine for me so far. I'll probably borrow the splitter once i get a bunch of wood lined up ready to go, but so far i've been scrounging for stuff so the piles haven't been too big. Scored pretty big tho recently, a buddy has a bunch of logs from removals in a pile, and they're ready to go just gotta cut and split it, so that's pretty awesome.
The splitter we built used a 2 stage pump and a larger sized single ram. It runs the pump at the large displacement most of the time so it's pretty quick but when the going gets tough the psi goes up, kicking a relief for the large displacement section and only pumping the smaller displacement stage. This goes much slower but has tons of power to split the bad stuff, just like a transmission would in a car dropping into low 4x4 or something. Once it's thru it goes back to fast, all done without your input as needed by the system. This also allows an engine to have a higher gpm than a single stage pump while still allowing it to be used at intermittent higher pressure to do the most demanding work. Usually they will develop higher pressures than a comparable sized single stage pump would too because they don't have to compromise with a single stage that has to do it all.
If i were to build one today i would like to try to build a kinetic one. The simplicity, speed, lack of hydraulics and associated headaches, and low hp requirements are attractive, and it would be cheaper since i have a good sized lathe now to help make parts rather than building an entire hydraulic system. I could also get my salvaged h press going and set up something in that, maybe even a 4 way. Then i can justify upgrading a bunch of parts on it and adding power to it :lol: That's the most likely outcome for me, it's a 50 ton they used for bending weld coupons. With power i could do good sized forging with it, broach keyways, press bearings, and set up an Ironworker type shear, punch, and brake to whip out parts in record time. That's enough to be worth it to suffer thru using it to split wood until i can figure out the next best laziest way to do this horrible task for minimal capital outlay since it's just for my house :lol:
When watching a splitter video I pay attention to how many moves the operator has to perform rather than the machine. I like the adjustable box wedge on that 22/28 but the log lifter would get in my way. I’ve come to like my little boom with the winch. Should have spent the extra money and used a winch with a wireless remote tho. Another project for another day.
