sotc
Dormant hero!!
So I got this thing home and starting to work on it. Found some 7k# axles that need to be 3.75 inches longer, working on that now. Also trying to figure out what size cylinder I need. I have a 6 qt., 3000# pump. The dump angle I show here is a 4' cylinder with 30" of throw which will max out my hyd. capacity with a 4" diameter cyl. With a 3.5" cylinder I could go 36" throw which would be better but I don't know if the power ratio is right. I'm hoping some of you can help me figure that out. I beleive 34 degrees will do it but more would be better. I have 66" from pivot point to bed pin and 112 to frame pin. Any help would be appreciated. Black rope shows where cylinder would be
