Buckingham Ergovation Pro Saddle - REVIEW
quabinclimber
MA
my buddy pick up an economy Ergovation and I got to fly it for a bit. It is very similar in style and set-up to a weaver leg strap saddle but a huge step up in comfort. It is fairly light weight and has good padding. When I wore the back pad on my waist it wanted to tip me backwards which I hate. Then I found if i wore it low on my hips like a tree-flex it sat me upright.
The leg strap pads are comfy but do tend to slide a bit during the climb but they are easily moved back into place. They also come up through your crotch like a weaver instead on around the leg. (digs in when turned to the side)
The bridge is just like a weaver sliding bridge and does the trick but does not respond like a rope bridge does. The side D;s are a little floppy but wont go past the 90 degree point (so they do not flip backwards)
all in all. If you dig weavers, you'll love this for not much of a price difference, not to mention it looks a whole lot nicer then a weaver. I'll keep flying my BFII and New Tribe
https://www.treestuff.com/store/catalog.asp?category_id=141&item=1829
