Boxer 532
arborworks1
hartsville, sc
Having trouble with a leak on the contol valve of the lift arm. There is a small pop out in between the ports on the valve. It doesn't appear to have a way to remove it.
Anyone experienced similar problems on boxer controls?
I thought the popup in the middle of the bottom pic was the culprit. After further dissection looks like a worn o ring in between the valve banks.
While it's out, it probably wouldn't be a bad idea to replace all the sectional o rings, given the minor time and expense while it's already out.
  • #10
Just finished putting everything back together. New o rings all around. Still leaking in the same spot.
I put in a call to compact power for a replacement valve bank. I can't stand for things to leak. Especially when it's leaking on top of a hot engine.
  • #11
So I went back into everything. Found a small o ring on the adapter coming out of the bank that was pinched flat. When I left the shop it was still dry and clean. Crossing my fingers that it's solved.
