pantheraba
More biners!!!
Alex (my son) hasn't climbed since Katrina..he recently bought a house to rent out and found this tree that needed to come down...he decided to climb this one :what:. We checked for good wood and found plenty. We also guyed it with a 9/16 Stable braid. (yes, it was starting to get dark...runs in the family)
Once he limbed it and left the spar (about 45 feet) I had to decide how to keep it out of the street and primaries.
I decided to make a small face cut to maximize my hinge wood (I also set a pull rope with a tightening system - some call it a Z-drag). I then bore cut from the street side where the most wood was, to establish a hinge. I got a wedge into the street side of the bore cut and started cutting towards the back - away from the hinge. When able, I put in a second wedge, my thinking was to prevent a tendency to sit toward the street.
I slowly made the cut to trip the back cut and got a "pop" which told me I had tripped the back holding strap. I pounded the wedges but the hinge was still plenty strong. I took out the front wedge and inserted the saw and slowly cut into the hinge, parallel to the hinge.
Once the spar started a slow lean into my pull rope, I pounded a few more times and went and tightened the pull rope. I pulled more and the tree committed to the fall I wanted.
Now that it is all done, any ideas on another way to have done it?
Any comments on using wedges along with a bore cut?
My bore cut was a few inches above the base of the face cut...I figured that might make a stronger hinge....true?
