Second Roger's thoughts on the terms... blcoking down a spar to me means using a block sling, and lowering line to rig down a spar, or "negative blocking", a term which I don't care for. Bombing wood down a spar is a rare occurance for me.. I will often rope stuff rather than leave the divets. I can't remember the last time I cut firewood sized pieces off a spar, and get hopping mad when I see a climber do it, which just occurs to me as a waste of the ground crew's time. I personally can't handle the dust, and will cut them as big as possible to minimize cutting time and breathing all that dust.
If the piece has front lean I'll use a snap cut, If I have to push, sometimes I'll use a snap cut, sometimes a small notch. Bigger stuff, I'll use a pull line on, with a small notch. I sometimes push as I cut with one hand, but generally think its an unnecessary practice, as a well made cut should allow the cutter to set the saw and push with two hands, while not taking much more time than cutting and pushing at the same time. Really bothers me when I see a bypass made on the notch, then the climber pushing with one hand, which would be completely unnecessary if the cut was made properly.
There was a highly experienced climber in Tenessee that managed to cut his arm completely off in that manner. Last crane job, I was one handing a cut at chest level and when the piece rocked back and to the side a little with the pretensioned cable, it grabbed the chain funny and started kicking the saw back towards my chest... Could have been deadly.. that'll never happen again.
